Ir para o conteúdo principal
Revlon 473 Heating Element Replacement
O que você precisa
  1. Revlon 473 Heating Element Replacement, Shell: passo 1, imagem 1 %32
    • Before disassembly, make sure that the device is unplugged.
    • Remove the two 17.83 mm black screws located on the handle.
  2. Revlon 473 Heating Element Replacement: passo 2, imagem 1 %32
    • Separate the shell from the main component.
    • Check to ensure each piece is free from debris.
  3. Revlon 473 Heating Element Replacement: passo 3, imagem 1 %32 Revlon 473 Heating Element Replacement: passo 3, imagem 2 %32 Revlon 473 Heating Element Replacement: passo 3, imagem 3 %32
    • Remove the casing from the heating element.
    • For reassembly, reattach the silver casing before the black cover.
  4. Revlon 473 Heating Element Replacement, Heating Element: passo 4, imagem 1 %32
    • The heating element is the group of tightly coiled bronze wires behind the vent hose as well as the silver coils.
    • Make sure that there are no breaks or debris obstructing the wires of the heating element.
  5. Revlon 473 Heating Element Replacement: passo 5, imagem 1 %32
    • To test the heating element, use a digital multimeter.
    • Set the multimeter to 200 under ACV.
    • Bring the ends of the multimeter toward the two lead wires.
    • If the circuit between the wires is closed, the numbers on the multimeter should keep changing.
    • If the numbers are not changing, replace the heating element.
    • If the circuit is closed, check the thermal cutout.
Conclusão
Jessica Leyva
Membro desde: 09/18/12
143 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 1-5, Propen Fall 2012 Membro de Cal Poly, Team 1-5, Propen Fall 2012
CPSU-PROPEN-F12S1G5
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 1,865
