Introdução
The gaskets and seals of this brewing unit are under much strain and have to be replaced from time to time.
The Nivona brewing unit (brewgroup) is identical with those of other brands, such as Bosch, Siemens or Melitta.
O que você precisa
Remove the hose connecting the upper piston and the coffee outlet.
Remove the upper piston.
Remove the Torx T20 screw from the screen of the upper piston.
Take off the cover of the gasket and the gasket.
Replace the gaskets of the upper piston, the coffee outlet and water connector.
Clean thoroughly all parts. Use food-proof silicone grease to lubricate the gaskets.
Apply all steps in reverse order to re-assemble the device.
3 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
100%
jana° está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
