Introdução
If the device is not turning on at all and is not responding, follow this guide to do a mainboard replacement (PCB) on the device. This process will take approximately 20-25 minutes, and the tools needed for the project are listed in the guide.
O que você precisa
Unplug any cables connected to the Retroid Pocket 3+.
Ensure your device has a charge of 5% or less as a charged battery can be dangerous if punctured.
Remove the three 4.5 mm screws with a Phillips #00 screwdriver on the main board.
