Introdução
If the device is not powering on or holding a charge, this guide will assist you in removing and replacing the battery in the Retroid Pocket 3+ safely. This process will take approximately 15-20 minutes, and the tools needed for the project are listed in this guide.
For your safety, turn off the device and ensure the battery is fully discharged before starting this process. If your battery looks puffy or swollen, take extra precautions when removing the battery. Remember to follow general electrostatic discharge (ESD) safety procedures when removing the battery.
Do not reuse the old battery after it has been removed, as it can cause a safety hazard.
O que você precisa
Unplug any cables connected to the Retroid Pocket 3+.
Ensure your device has a charge of 5% or less as a charged battery can be dangerous if punctured.
