Ir para o conteúdo principal
Retro-Bit Retro Duo Controller Button and Pad Replacement.
O que você precisa
  1. Retro-Bit Retro Duo Controller Button and Pad Replacement., Buttons and Pads in Controller(s): passo 1, imagem 1 %32 Retro-Bit Retro Duo Controller Button and Pad Replacement., Buttons and Pads in Controller(s): passo 1, imagem 2 %32 Retro-Bit Retro Duo Controller Button and Pad Replacement., Buttons and Pads in Controller(s): passo 1, imagem 3 %32
    • With the controller on its face, remove the five 6 mm Phillips #1 screws.
    • After screw removal, carefully lift the controller casing.
  2. Retro-Bit Retro Duo Controller Button and Pad Replacement.: passo 2, imagem 1 %32 Retro-Bit Retro Duo Controller Button and Pad Replacement.: passo 2, imagem 2 %32 Retro-Bit Retro Duo Controller Button and Pad Replacement.: passo 2, imagem 3 %32
    • Pinch the top and bottom of the shoulder pads, then lift out.
    • There are small elastic pads below each shoulder pad. Replace these if they are not functioning correctly.
  3. Retro-Bit Retro Duo Controller Button and Pad Replacement.: passo 3, imagem 1 %32 Retro-Bit Retro Duo Controller Button and Pad Replacement.: passo 3, imagem 2 %32 Retro-Bit Retro Duo Controller Button and Pad Replacement.: passo 3, imagem 3 %32
    • Carefully lift the circuit board from the controller case.
  4. Retro-Bit Retro Duo Controller Button and Pad Replacement.: passo 4, imagem 1 %32 Retro-Bit Retro Duo Controller Button and Pad Replacement.: passo 4, imagem 2 %32 Retro-Bit Retro Duo Controller Button and Pad Replacement.: passo 4, imagem 3 %32
    • To replace the action button pad, lift this part out.
    • Lift the Select and Start button pad.
    • If replacing the D-Pad, lift this pad.
    • Pinch and lift the shoulder button pads.
  5. Retro-Bit Retro Duo Controller Button and Pad Replacement.: passo 5, imagem 1 %32 Retro-Bit Retro Duo Controller Button and Pad Replacement.: passo 5, imagem 2 %32 Retro-Bit Retro Duo Controller Button and Pad Replacement.: passo 5, imagem 3 %32
    • Support the controller face and push buttons toward the inner case.
    • Use care. The buttons have a tiny tab to keep them in place.
    • Support the controller face and push the D-Pad toward the inner case.
Conclusão
Evelyn
Membro desde: 09/25/17
223 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S4-G4, Eyestone Fall 2017 Membro de USF Tampa, Team S4-G4, Eyestone Fall 2017
USFT-EYESTONE-F17S4G4
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Duração total: 1,211
