Ir para o conteúdo principal
Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement
O que você precisa
  1. Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement, Circuit Board in Controller(s): passo 1, imagem 1 %32 Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement, Circuit Board in Controller(s): passo 1, imagem 2 %32 Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement, Circuit Board in Controller(s): passo 1, imagem 3 %32
    • With the controller on its face, remove the five 6 mm Phillips #1 screws.
    • After removing the screws, carefully lift the controller casing .
  2. Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement: passo 2, imagem 1 %32 Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement: passo 2, imagem 2 %32 Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement: passo 2, imagem 3 %32
    • Pinch the top and bottom of the shoulder buttons and lift them out.
    • Below each shoulder button, there are small elastic pads. To remove them, pinch the pads and slide them out.
    • Removing the elastic pads allows easier circuit board access.
  3. Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement: passo 3, imagem 1 %32 Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement: passo 3, imagem 2 %32 Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement: passo 3, imagem 3 %32
    • Carefully lift the circuit board from the controller case.
Conclusão
Evelyn
Membro desde: 09/25/17
228 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S4-G4, Eyestone Fall 2017 Membro de USF Tampa, Team S4-G4, Eyestone Fall 2017
USFT-EYESTONE-F17S4G4
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 7
Últimos 30 dias: 11
Ao todo: 1,158
