Ir para o conteúdo principal
Respironics REMstar Plus M Series Power Supply Circuit board Replacement
O que você precisa
  1. Respironics REMstar Plus M Series Power Supply Circuit board Replacement, Power Supply Circuit board: passo 1, imagem 1 %32 Respironics REMstar Plus M Series Power Supply Circuit board Replacement, Power Supply Circuit board: passo 1, imagem 2 %32 Respironics REMstar Plus M Series Power Supply Circuit board Replacement, Power Supply Circuit board: passo 1, imagem 3 %32
    • Place the device face down.
    • Use a T15 Torx screwdriver to remove the six screws in the base plate.
    • Lift the base plate off of the device.
  2. Respironics REMstar Plus M Series Power Supply Circuit board Replacement: passo 2, imagem 1 %32 Respironics REMstar Plus M Series Power Supply Circuit board Replacement: passo 2, imagem 2 %32 Respironics REMstar Plus M Series Power Supply Circuit board Replacement: passo 2, imagem 3 %32
    • Flip the circuit board over to the right.
    • Gently pull the ribbon cable outward to disconnect it from the circuit board.
  3. Respironics REMstar Plus M Series Power Supply Circuit board Replacement: passo 3, imagem 1 %32 Respironics REMstar Plus M Series Power Supply Circuit board Replacement: passo 3, imagem 2 %32
    • Disconnect the red 3-wire plug at the top left of the board and the white 4-wire plug at the bottom left.
    • Remove the circuit board.
Conclusão
2 comentários
My unit stops working in the middle of the night, then beeps, & blue light flashes. Will replacing this board fix this, and where can I get one?
mert454 - Responder
Where to find a power supply circuit board for my Remstar plus m series which just blinks blue lights. dledes@shaw.ca
David Edes - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 19
Duração total: 984
