Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
To soft reset the device, use a paperclip to carefully press the reset button located on the back of the device. The exact location of the button can be seen in the picture.
After you press the button, the device will reboot as if you just powered on your device and it should clear up most common device problems.
If your device is still not powering up or has a blank display, the next step will help you perform a hard reset of the device.
A hard reset is done by simultaneously holding down the power button while also pressing the reset button on the back with a paper clip like you did for the soft reset. After a few seconds the Palm logo should appear, when it does, release the power button.
