Ir para o conteúdo principal
ResMed VPAP Auto 25 Circuit Board Replacement
O que você precisa
  1. ResMed VPAP Auto 25 Circuit Board Replacement, Circuit Board: passo 1, imagem 1 %32 ResMed VPAP Auto 25 Circuit Board Replacement, Circuit Board: passo 1, imagem 2 %32 ResMed VPAP Auto 25 Circuit Board Replacement, Circuit Board: passo 1, imagem 3 %32
    • Remove the four 26.7 mm T3 Torx screws from the bottom side of the ResMed VPAP Auto 25.
  2. ResMed VPAP Auto 25 Circuit Board Replacement: passo 2, imagem 1 %32 ResMed VPAP Auto 25 Circuit Board Replacement: passo 2, imagem 2 %32 ResMed VPAP Auto 25 Circuit Board Replacement: passo 2, imagem 3 %32
    • Flip the device over.
    • Pry the outermost plastic cover off with the metal spudger until the cover is loose and able to be removed.
  3. ResMed VPAP Auto 25 Circuit Board Replacement: passo 3, imagem 1 %32 ResMed VPAP Auto 25 Circuit Board Replacement: passo 3, imagem 2 %32
    • Pull off the front cover to reveal the internal components.
  4. ResMed VPAP Auto 25 Circuit Board Replacement: passo 4, imagem 1 %32 ResMed VPAP Auto 25 Circuit Board Replacement: passo 4, imagem 2 %32 ResMed VPAP Auto 25 Circuit Board Replacement: passo 4, imagem 3 %32
    • Loosen the motherboard from the rubber dowels holding it in place and unplug the screen components.
  5. ResMed VPAP Auto 25 Circuit Board Replacement: passo 5, imagem 1 %32 ResMed VPAP Auto 25 Circuit Board Replacement: passo 5, imagem 2 %32 ResMed VPAP Auto 25 Circuit Board Replacement: passo 5, imagem 3 %32
    • Remove the three 26.7 mm T3 Torx screws from the now visible rubber fan motor cover.
    • Lift off the rubber fan motor cover, revealing the fan motor.
  6. ResMed VPAP Auto 25 Circuit Board Replacement: passo 6, imagem 1 %32 ResMed VPAP Auto 25 Circuit Board Replacement: passo 6, imagem 2 %32 ResMed VPAP Auto 25 Circuit Board Replacement: passo 6, imagem 3 %32
    • Remove the fan motor unit from its housing.
    • Remove the three 26.7 mm screws securing the motor housing to the bottom piece with a T3 Torx screwdriver.
  7. ResMed VPAP Auto 25 Circuit Board Replacement: passo 7, imagem 1 %32 ResMed VPAP Auto 25 Circuit Board Replacement: passo 7, imagem 2 %32 ResMed VPAP Auto 25 Circuit Board Replacement: passo 7, imagem 3 %32
    • Pull out the fan motor housing from the bottom cover, revealing a foam insulation pad and the circuit board.
    • Slide the circuit board out of its plastic grooves in the bottom cover to retrieve the desired component.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 233
