Ir para o conteúdo principal
ResMed VPAP Auto 25 Blower Unit Replacement Replacement
O que você precisa
  1. ResMed VPAP Auto 25 Blower Unit Replacement Replacement, Blower Unit: passo 1, imagem 1 %32 ResMed VPAP Auto 25 Blower Unit Replacement Replacement, Blower Unit: passo 1, imagem 2 %32 ResMed VPAP Auto 25 Blower Unit Replacement Replacement, Blower Unit: passo 1, imagem 3 %32
    • Remove the four 26.7 mm T3 Torx screws from the bottom side of the ResMed VPAP Auto 25.
  2. ResMed VPAP Auto 25 Blower Unit Replacement Replacement: passo 2, imagem 1 %32 ResMed VPAP Auto 25 Blower Unit Replacement Replacement: passo 2, imagem 2 %32 ResMed VPAP Auto 25 Blower Unit Replacement Replacement: passo 2, imagem 3 %32
    • Flip the device over.
    • Pry the outermost plastic cover off with the metal spudger until the cover is loose and able to be removed.
  3. ResMed VPAP Auto 25 Blower Unit Replacement Replacement: passo 3, imagem 1 %32 ResMed VPAP Auto 25 Blower Unit Replacement Replacement: passo 3, imagem 2 %32
    • Pull off the front cover to reveal the internal components.
  4. ResMed VPAP Auto 25 Blower Unit Replacement Replacement: passo 4, imagem 1 %32 ResMed VPAP Auto 25 Blower Unit Replacement Replacement: passo 4, imagem 2 %32 ResMed VPAP Auto 25 Blower Unit Replacement Replacement: passo 4, imagem 3 %32
    • Loosen the motherboard from the rubber dowels holding it in place and unplug the screen components.
  5. ResMed VPAP Auto 25 Blower Unit Replacement Replacement: passo 5, imagem 1 %32 ResMed VPAP Auto 25 Blower Unit Replacement Replacement: passo 5, imagem 2 %32 ResMed VPAP Auto 25 Blower Unit Replacement Replacement: passo 5, imagem 3 %32
    • Remove the three 26.7 mm T3 Torx screws from the now visible rubber fan motor cover.
    • Lift off the rubber fan motor cover, revealing the fan motor.
  6. ResMed VPAP Auto 25 Blower Unit Replacement Replacement: passo 6, imagem 1 %32
    • Unplug the blower unit cable.
    • Remove the fan motor blower unit.
Conclusão
Uma outra pessoa concluiu este guia.
Um comentário
where can we get a new motor?
ed allen - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 307
