Introdução
If your device is having internet or network issues, the cause might be a broken wireless communication board. If this is the cause, this guide can help you to replace the broken board.
Be sure to confirm that the internet issues are due to the device itself. The wifi network it is connected to could also be the cause of the problems. To easily test this, just make sure other devices can connect to the internet properly.
O que você precisa
Place a halberd spudger behind the connector cable.
Use a halberd spudger to pull the connector away from the motherboard.
2 comentários
I have an early ResMed Airsense 10 and my wireless comm board was 3G. Can this be updated with a replacement board?
