Introdução
Over time the rubber seal on the air outlet elbow of the ResMed AirSense 10 medical ventilator will wear and cause small air leaks. If the hose and mask are verified to be not leaking, the leak can be located on the air outlet elbow. Check the air outlet elbow when trouble shooting leakages and replace as needed.
O que você precisa
Position the ResMed Airsense 10 with the water reservoir facing towards you.
Remove the ResMed water tank.
5 outras pessoas executaram este guia.
