Introdução
Here you can find out how to change the power switch on your Blaupunkt TV. If your Blaupunkt LCD TV no longer switches on reliably, the power switch may be faulty. These instructions will guide you step by step through the replacement of the power switch. Attention: Electrical knowledge is required.
O que você precisa
Make sure that the device is disconnected from the power supply before starting the repair.
Removing the power switch is quite simple. First open the housing by removing all the screws on the rear panel, which are marked with an arrow.
Then carefully lift off the back panel and disconnect any cables that prevent the back panel from being lifted off.
Now press the retaining clips that hold the switch in the TV housing together with needle-nose pliers and clip the switch out of the TV housing. Use a flat-blade screwdriver to assist with that if necessary.
You should have some electrotechnical knowledge so that you will be able to correctly position the connectors on the new switch.
Now just clip on the switch. Plug in the disconnected cables. Fit rear panel and screw in all screws again.
Description on the original switch: LECI RS601D more details 6 (4) A250VAC new line: 10A 125VAC - other side: 6A250VAC new line: 6A / 125A250VAC -
My problem was that the power switch was broken and the TV could only be switched on sporadically.
On Ebay, the switch RS601D (as of June 2017), is available as an original from China. An alternative: Since I just had it on hand, I installed the following switch from Pollin: # 420427 (unfortunately, no indication of inrush current found)
Probably also suitable: Marquardt 1858.1103 rocker switch, black, plug-in 4.8 mm, 10 (4.0) A / 250 VAC, 6.0 (4.0) A / 250 VAC e.g. from Bürklin: # 11 G 2854 - € 1.94
As already mentioned - connect the cable to the new switch and snap the snap-in switch back into the housing. Replace the rear panel and screw the screws back in where they were unscrewed.
3 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
