Ir para o conteúdo principal
Replacing the battery of a Lunii - My Story Factory v2
O que você precisa
  1. Replacing the battery of a Lunii - My Story Factory v2, Unscrew the screws: passo 1, imagem 1 %32
    • Remove the 4 Torx 6 screws located at the back of the device.
    • Since the screws are housed at the bottom of a hole, you will need a particularly long bit or even better, a screwdriver.
  2. Replacing the battery of a Lunii - My Story Factory v2, Open the box: passo 2, imagem 1 %32 Replacing the battery of a Lunii - My Story Factory v2, Open the box: passo 2, imagem 2 %32 Replacing the battery of a Lunii - My Story Factory v2, Open the box: passo 2, imagem 3 %32
    • Separate the two parts of the box, taking care to open the box well from the top, so that you end up with the contents of the box still in place in each of the halves.
  3. Replacing the battery of a Lunii - My Story Factory v2, Remove the battery from its housing.: passo 3, imagem 1 %32 Replacing the battery of a Lunii - My Story Factory v2, Remove the battery from its housing.: passo 3, imagem 2 %32
    • Remove the battery from its housing.
  4. Replacing the battery of a Lunii - My Story Factory v2, Disconnect the battery: passo 4, imagem 1 %32 Replacing the battery of a Lunii - My Story Factory v2, Disconnect the battery: passo 4, imagem 2 %32
    • The connector needs to be removed very gently.
    • Depending on the connector, some force may be required.
  5. Replacing the battery of a Lunii - My Story Factory v2, Battery: passo 5, imagem 1 %32
    • Replace the battery with a new one of the same voltage (Volts). The capacity (mAh) can be the same (ideal), or higher (charging will take longer but last longer) or lower (charging will take faster but last less time).
Conclusão
To reassemble your device, follow these same instructions in reverse order.
Um agradecimento especial a esses tradutores:
fr en
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Benoit74
Membro desde: 11/15/21
2.944 Reputação
Autoria de 11 guias
10 comentários
Bonsoir Benoit74,
Merci pour ce mini tutoriel.
Je compte changer la batterie de la Lunii familiale, mais je rencontre quelques difficultés pour trouver une batterie Li-ion qui ressemble vaguement à celle d'origine. Toutes les batteries qui ont l'air de faire l'affaire sont des Li-Po. Est-ce en fait la même chose, mais sous différents noms ? D'un côté, je trouve des sites qui expliquent que ce sont deux choses bien différents ; de l'autre je trouve la page wikipedia qui dit que les LiPo devraient plutôt s'appeler lithium-ion polymer...
Peux-tu m'aider ?
Antonio Terra - Responder
Bonjour,
On la trouve par exemple sur AliExpress assez facilement : https://fr.aliexpress.com/item/100500133...
Concernant Li-Po vs Li-Ion, ce ne sont effectivement pas les même batteries ; je ne sais pas si le contrôleur de charge de la Lunii 2 est capable de gérer correctement les deux types de batteries. Concernant le fait que les gens disent que la Li-Po devrait s'appeller Li-Ion Po, ce qu'il veulent dire c'est que les Li-Po restent une sorte de batterie Li-Ion très spécifique.
Benoit74 - Responder
Merci beaucoup pour ces explications qui viennent à bout d'une partie de ma confusion !
Antonio Terra -
Bonjour Benoit,
L'exemple sur AliExpress ne comporte pas de Pin de connexion / de prise... Les fils sont nus. J'ai trouvé un modèle avec PIN : https://www.ebay.fr/itm/234311520496 connais-tu le modèle de connecteur ?
Belle journée,
David
David -
Bonjour,
Merci pour ce tuto 👍🏻
Peut-on mettre une batterie supérieure à 600mha ?
Adrian Esquerré - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 29
Últimos 7 dias: 245
Últimos 30 dias: 976
Duração total: 7,701
