Ir para o conteúdo principal
Replacing the Slider on a Coil Zipper
O que você precisa
Vídeo de Apresentação
  1. Replacing the Slider on a Coil Zipper, Coil Zipper Slider: passo 1, imagem 1 %32 Replacing the Slider on a Coil Zipper, Coil Zipper Slider: passo 1, imagem 2 %32 Replacing the Slider on a Coil Zipper, Coil Zipper Slider: passo 1, imagem 3 %32
    • Locate the top of the zipper on the side with the slider.
    • Peel back any fabric that is covering the zipper stop.
  2. Replacing the Slider on a Coil Zipper: passo 2, imagem 1 %32 Replacing the Slider on a Coil Zipper: passo 2, imagem 2 %32
    • Use end nippers to cut the stop.
    • Be sure to only cut the plastic or metal stop. You do not want to damage the webbing behind the zipper.
    This picture particularly needs to be much more close up. The critical part must fill the image. Or insert the close-up after this one: only zipper end (maybe thumbnail) and end of nipper.
    Dale Mead - Responder
  3. Replacing the Slider on a Coil Zipper: passo 3, imagem 1 %32
    • Carefully remove any remaining pieces of the stop using tweezers.
    See prior comment
  4. Replacing the Slider on a Coil Zipper: passo 4, imagem 1 %32 Replacing the Slider on a Coil Zipper: passo 4, imagem 2 %32 Replacing the Slider on a Coil Zipper: passo 4, imagem 3 %32
    • Slide the damaged zipper slider up and off of the zipper.
  5. Replacing the Slider on a Coil Zipper: passo 5, imagem 1 %32 Replacing the Slider on a Coil Zipper: passo 5, imagem 2 %32
    • Slide the replacement slider onto the zipper.
    • You may need to tug a little to get it past where the old stop was.
    • Make sure that your zipper slider is facing the correct way (right-side up) when you place it onto the zipper.
  6. Replacing the Slider on a Coil Zipper: passo 6, imagem 1 %32 Replacing the Slider on a Coil Zipper: passo 6, imagem 2 %32
    • Grab a new zipper stop.
    • Insert the teeth into the webbing in the same place where the old stop was located.
  7. Replacing the Slider on a Coil Zipper: passo 7, imagem 1 %32 Replacing the Slider on a Coil Zipper: passo 7, imagem 2 %32 Replacing the Slider on a Coil Zipper: passo 7, imagem 3 %32
    • Use pliers to bend the metal top of the zipper stop around the edge of the webbing, poking the single tooth on the stop through the backside of the webbing.
    • Crimp the stop into place.
    Comment déterminer la taille de curseur ? Où peut-on acheter un nouveau curseur. Merci pour votre réponse.
    danka hojcusova - Responder
    Hi Danka, Call Patagonia Customer Service for the specific Slider type and size you need including the zipper stop. 1-800-638-6464.
    Marty Chapman -
    If ok photo shown closedly to the zipper.tq fyi..
    Primo123 Primo123 - Responder
    Hello! I am looking forward to repairing my Patagonia zipper on my R1 half zip men’s shirt. However, you do not show how to engage the new zipper pull on both sides, only one. How are you supposed to get the zipper onto both sides?
    John Juba - Responder
Linha de Chegada
19 outras pessoas executaram este guia.
Brittany McCrigler
Membro desde: 03/05/12
89.014 Reputação
Autoria de 131 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.816 guias
11 comentários
Where do I get the zipper stop????
Jason Heimink - Responder
How do you find the size slider(in my case 5 millimetres) and also the right size teeth that will fit into the zipper.
bbehrhorst - Responder
I used this Guide to replace the zipper slide on my wife's favorite Disney fleece jacket. I purchased my slide and the stop online. Since I'm not sure about the rules on posting vendor's info, I will say GOOGLE "nylon coil zipper slide". You can have your "zippershipped" right to your door.
kasten39828 - Responder
AWESOME! Thanks for the pointers - I’m ready for tomorrow’s powder day!!!!
Jenny - Responder
Great now how ! thank’s :)
Robert Fyfe - Responder
Oh my goodness, thank you so much! You saved me during the pandemic. Super clear instructions, even though I had a metal zipper and cotton sweatshirt. Patagonia sent me more than all the parts I needed. Thank you again!
Katharine Morrison - Responder
How do I get spare parts, zipper slider and stopper?
Peter Hofer - Responder
Hi All, you can contact Patagonia Customer Service for any spare parts you need for repairing a Patagonia item.
Maike - Responder
Hi All, you can contact Patagonia Customer Service for any spare parts you need for a repair of a Patagonia item.
Maike - Responder
Tips on where to get parts for non-Patagonia garments?
To determine what type and size of slider you might need, please check out this guide below. Video: Introduction to Zipper Types and Slider Identification
Once you know which type and size you need contact Patagonia Customer Service ( 1-800-638-6464) for a new Slider and Zipper Stop. Please have your type and size available to provide to the CS Agent.
Tools for the job were listed above in the "Tools" section, if you place your cursor over the link a little window will pop up. If you click on it it will take you to a vendor to purchase any tool that needed.
Good Luck.
Marty Chapman - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 25
Últimos 7 dias: 146
Últimos 30 dias: 575
Duração total: 98,681
