Ir para o conteúdo principal
Replacing the Slider on a Coil Zipper
O que você precisa
Vídeo de Apresentação
  1. Replacing the Slider on a Coil Zipper, Coil Zipper Slider: passo 1, imagem 1 %32 Replacing the Slider on a Coil Zipper, Coil Zipper Slider: passo 1, imagem 2 %32 Replacing the Slider on a Coil Zipper, Coil Zipper Slider: passo 1, imagem 3 %32
    • Locate the top of the zipper on the side with the slider.
    • Peel back any fabric that is covering the zipper stop.
  2. Replacing the Slider on a Coil Zipper: passo 2, imagem 1 %32 Replacing the Slider on a Coil Zipper: passo 2, imagem 2 %32
    • Use end nippers to cut the stop.
    • Be sure to only cut the plastic or metal stop. You do not want to damage the webbing behind the zipper.
  3. Replacing the Slider on a Coil Zipper: passo 3, imagem 1 %32
    • Carefully remove any remaining pieces of the stop using tweezers.
  4. Replacing the Slider on a Coil Zipper: passo 4, imagem 1 %32 Replacing the Slider on a Coil Zipper: passo 4, imagem 2 %32 Replacing the Slider on a Coil Zipper: passo 4, imagem 3 %32
    • Slide the damaged zipper slider up and off of the zipper.
  5. Replacing the Slider on a Coil Zipper: passo 5, imagem 1 %32 Replacing the Slider on a Coil Zipper: passo 5, imagem 2 %32
    • Slide the replacement slider onto the zipper.
    • You may need to tug a little to get it past where the old stop was.
    • Make sure that your zipper slider is facing the correct way (right-side up) when you place it onto the zipper.
  6. Replacing the Slider on a Coil Zipper: passo 6, imagem 1 %32 Replacing the Slider on a Coil Zipper: passo 6, imagem 2 %32
    • Grab a new zipper stop.
    • Insert the teeth into the webbing in the same place where the old stop was located.
  7. Replacing the Slider on a Coil Zipper: passo 7, imagem 1 %32 Replacing the Slider on a Coil Zipper: passo 7, imagem 2 %32 Replacing the Slider on a Coil Zipper: passo 7, imagem 3 %32
    • Use pliers to bend the metal top of the zipper stop around the edge of the webbing, poking the single tooth on the stop through the backside of the webbing.
    • Crimp the stop into place.
Linha de Chegada
19 outras pessoas executaram este guia.
Brittany McCrigler
Membro desde: 03/05/12
89.014 Reputação
Autoria de 131 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.817 guias
11 comentários
Where do I get the zipper stop????
Jason Heimink - Responder
How do you find the size slider(in my case 5 millimetres) and also the right size teeth that will fit into the zipper.
bbehrhorst - Responder
I used this Guide to replace the zipper slide on my wife's favorite Disney fleece jacket. I purchased my slide and the stop online. Since I'm not sure about the rules on posting vendor's info, I will say GOOGLE "nylon coil zipper slide". You can have your "zippershipped" right to your door.
kasten39828 - Responder
AWESOME! Thanks for the pointers - I’m ready for tomorrow’s powder day!!!!
Jenny - Responder
Great now how ! thank’s :)
Robert Fyfe - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 25
Últimos 7 dias: 149
Últimos 30 dias: 578
Duração total: 98,684
