Ir para o conteúdo principal
Replacing the Battery on a BLU Vivo 5
O que você precisa
  1. Replacing the Battery on a BLU Vivo 5, Remove bottom screws.: passo 1, imagem 1 %32 Replacing the Battery on a BLU Vivo 5, Remove bottom screws.: passo 1, imagem 2 %32
    • Remove the P2 screws.
    • Remove the SIM and SD cards, as well as the adapter.
  2. Replacing the Battery on a BLU Vivo 5, Remove the top cover.: passo 2, imagem 1 %32 Replacing the Battery on a BLU Vivo 5, Remove the top cover.: passo 2, imagem 2 %32 Replacing the Battery on a BLU Vivo 5, Remove the top cover.: passo 2, imagem 3 %32
    • Pull off the protective cover from the camera.
    • Remove the screws with a #00 Phillips screwdriver.
  3. Replacing the Battery on a BLU Vivo 5, Remove bottom cover.: passo 3, imagem 1 %32 Replacing the Battery on a BLU Vivo 5, Remove bottom cover.: passo 3, imagem 2 %32 Replacing the Battery on a BLU Vivo 5, Remove bottom cover.: passo 3, imagem 3 %32
    • To remove the bottom cover, pull it upward.
  4. Replacing the Battery on a BLU Vivo 5, Releasing the back cover.: passo 4, imagem 1 %32 Replacing the Battery on a BLU Vivo 5, Releasing the back cover.: passo 4, imagem 2 %32 Replacing the Battery on a BLU Vivo 5, Releasing the back cover.: passo 4, imagem 3 %32
    • Use a spudger to carefully apply pressure to the indicated areas to remove the cover.
    • Remove the microphone/speaker board assembly by pulling downward.
  5. Replacing the Battery on a BLU Vivo 5, Removing the battery.: passo 5, imagem 1 %32 Replacing the Battery on a BLU Vivo 5, Removing the battery.: passo 5, imagem 2 %32 Replacing the Battery on a BLU Vivo 5, Removing the battery.: passo 5, imagem 3 %32
    • The battery has a small notch to facilitate removal, but the battery has been glued in place.
    • To remove the battery, pry under it with a thin tool and slide from one side to the other slowly, listening for the sound of the battery coming loose.
Conclusão
3 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
es en
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Eneider Colina
Membro desde: 09/20/13
2.370 Reputação
Autoria de 9 guias
Equipe
Comunidad para traductores de español Membro de Comunidad para traductores de español
Community
Membros da 29
Autoria de 334 guias
2 comentários
Umm not sure what BLU Vivo 5 your giving these instructions for, my BLU Vivo 5 has no screws. Looks the same except for bottom speaker area, mine has type c and other wither side 2 slots one for mic one for speaker, no screws.
V'Ger_iTech - Responder
This guide is NOT for BLU Vivo 5. It's probably for the mini version. The BLU vivo 5 doesn't have screws at bottom...
Alaziz Hussain - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 32
Duração total: 4,126
