Introdução
Not even a screw is required to change the bios battery.
By replacing the CMOS battery the setting will be erased and set by default, in case of problems with the bios its common practice to remove and reinsert the battery to reset it.
O que você precisa
Documento em destaque
Press the two green tabs and pull up the fan on the CPUs
Press on the clip (in red) and the battery should come out by itself
Insert the new battery
By replacing the CMOS battery the settings should remain saved
Um agradecimento especial a esses tradutores:
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
