Ir para o conteúdo principal
Replacing strings on an All American Bass
O que você precisa
  1. Replacing strings on an All American Bass, Loosen the tuners. By twisting the peg clockwise.: passo 1, imagem 1 %32
    • Caution: Be careful when working on tensioned strings. Wear protective gear (eyewear, gloves) if possible.
    • Loosen by clockwise.
  2. Replacing strings on an All American Bass, Pull the G-string (the string with the highest pitch) from the peg.: passo 2, imagem 1 %32
    • Can be different per bass.
  3. Replacing strings on an All American Bass, Pull the string from the bridge.: passo 3, imagem 1 %32
    • Pull through the hole near the spring.
  4. Replacing strings on an All American Bass, Count the rivets on the old string to ascertain how many twists are needed.: passo 4, imagem 1 %32
    • This can be done by counting the rivets in old string.
  5. Replacing strings on an All American Bass, Thread the new strings through the bridge over the groove.: passo 5, imagem 1 %32
    • Reverse Step 4.
  6. Replacing strings on an All American Bass, Pull the string up to the tuner head and place it in-to the hole.: passo 6, imagem 1 %32
    • CAUTION: Can lead to string snapping and hurting one self.
  7. Replacing strings on an All American Bass, Wrap the string around the tuner peg counter-clockwise.: passo 7, imagem 1 %32
  8. Replacing strings on an All American Bass, Tighten the string by twisting the peg counter-clockwise.: passo 8, imagem 1 %32
  9. Replacing strings on an All American Bass, Hold the end of the tuner and turn the peg until the bass has been suitably tuned.: passo 9, imagem 1 %32
    • Use a phone tuner or regular guitar tuner.
  10. Replacing strings on an All American Bass, Repeat steps 1-9 for all re-maining strings.: passo 10, imagem 1 %32
    • You're Done!
Conclusão
Your bass should now be restrung correctly and ready to rock out.
Uma outra pessoa concluiu este guia.
Jeffrey Baston
Membro desde: 10/26/15
1 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 142
