Ir para o conteúdo principal
Introdução
Bass guitars have been in use for the past century to make music more enjoyable, provides a beat for other instruments being played, and allows a nice background tone for various gen-res; mostly Rock n’ Roll. Various companies produce bass’ that have varying sound, inputs and outputs, design, and usability (such as the steel-lap bass vs. normal free hand bass). Whether you are using your bass for personal enjoyment and learning, or play professionally, our guide can help you string your bass efficiently and with clear understanding. This ensures that you can get back playing minutes later, and can keep rocking out the way you do.
Ferramentas
Peças
  1. Caution: Be careful when working on tensioned strings. Wear protective gear (eyewear, gloves) if possible.
    • Caution: Be careful when working on tensioned strings. Wear protective gear (eyewear, gloves) if possible.
    • Loosen by clockwise.
  2. Can be different per bass.
    • Can be different per bass.
  3. Pull through the hole near the spring.
    • Pull through the hole near the spring.
  4. This can be done by counting the rivets in old string.
    • This can be done by counting the rivets in old string.
  5. Reverse Step 4.
    • Reverse Step 4.
  6. CAUTION: Can lead to string snapping and hurting one self.
    • CAUTION: Can lead to string snapping and hurting one self.
  7. CAUTION: Can lead to string snapping and hurting one self.
  8. CAUTION: Can lead to string snapping and hurting one self.
  9. Use a phone tuner or regular guitar tuner.
    • Use a phone tuner or regular guitar tuner.
  10. You're Done!
    • You're Done!
Conclusão
Your bass should now be restrung correctly and ready to rock out.
Uma outra pessoa concluiu este guia.
Jeffrey Baston
Membro desde: 26/10/2015
1 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 111
