Ir para o conteúdo principal
Replacing flash memory to a cisco 837 series router
O que você precisa
  1. Replacing flash memory to a cisco 837 series router, Flash memory: passo 1, imagem 1 %32
    • CISCO 837 Router
    • CISCO 877 Router
Conclusão
CONCLUSION
Replacing flash need a tftp server available;
Replacing flash need a copy of the IOS image;
Replacing flash need the usage of ROMMON; be sure that this is possible;
Removing the flash card and inserting it back is like replacing with a new one (IOS image will be gone, so don’t play it with ease);
use the first ethernet port to connect with the tftp server, although all 4 switch ports will work presumably because all being in the same first VLAN.
To reassemble your device, follow these instructions in reverse order and that's all.
Uma outra pessoa concluiu este guia.
Eneider Colina
Membro desde: 09/20/13
2.370 Reputação
Autoria de 9 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Ao todo: 1,473
