Ir para o conteúdo principal
Replacing a Zipper Pull Tab on your Patagonia Jacket
Vídeo de Apresentação
Zipper pull replacement overview.
  1. Replacing a Zipper Pull Tab on your Patagonia Jacket, Zipper Pull Tab: passo 1, imagem 1 %32 Replacing a Zipper Pull Tab on your Patagonia Jacket, Zipper Pull Tab: passo 1, imagem 2 %32
    • Get your new zipper pull and position it with the pull-tab down.
    • Lift up the zipper, as if you were pulling the zipper closed.
  2. Replacing a Zipper Pull Tab on your Patagonia Jacket: passo 2, imagem 1 %32 Replacing a Zipper Pull Tab on your Patagonia Jacket: passo 2, imagem 2 %32 Replacing a Zipper Pull Tab on your Patagonia Jacket: passo 2, imagem 3 %32
    • Insert the zipper pull into the smaller hole in the zipper. This is the top hole when the zipper is hanging normally.
    • Pull the zipper pull through the smaller hole.
  3. Replacing a Zipper Pull Tab on your Patagonia Jacket: passo 3, imagem 1 %32 Replacing a Zipper Pull Tab on your Patagonia Jacket: passo 3, imagem 2 %32
    • Rest the zipper back in its normal, hanging position.
    • Take top end of the zipper pull and insert it into the bigger, lower hole in the zipper.
  4. Replacing a Zipper Pull Tab on your Patagonia Jacket: passo 4, imagem 1 %32 Replacing a Zipper Pull Tab on your Patagonia Jacket: passo 4, imagem 2 %32
    • Pull the top of the zipper pull through the hole to create a loop on the backside of the zipper.
    • Bring the zipper pull-tab through the loop.
  5. Replacing a Zipper Pull Tab on your Patagonia Jacket: passo 5, imagem 1 %32 Replacing a Zipper Pull Tab on your Patagonia Jacket: passo 5, imagem 2 %32
    • Pull the zipper pull-tab snug.
    • The zipper pull should now be inserted and lay flat.
Linha de Chegada
4 outras pessoas executaram este guia.
Brittany McCrigler
Membro desde: 03/05/12
89.017 Reputação
Autoria de 131 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.817 guias
Um comentário
Awesome! Thanks for the training!
Kathleen Hutton - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 26
Últimos 30 dias: 139
Duração total: 24,478
