Ir para o conteúdo principal
Replacing a Wheel on your Patagonia Wheeled Luggage
O que você precisa
  1. Replacing a Wheel on your Patagonia Wheeled Luggage, Wheel: passo 1, imagem 1 %32
    • Lay the bag down, with the problem wheel facing you.
    • Zipping the bag closed will keep it from flopping about as you work.
  2. Replacing a Wheel on your Patagonia Wheeled Luggage: passo 2, imagem 1 %32 Replacing a Wheel on your Patagonia Wheeled Luggage: passo 2, imagem 2 %32 Replacing a Wheel on your Patagonia Wheeled Luggage: passo 2, imagem 3 %32
    • Using a hex 4.0 screwdriver, remove the threaded bolt in the center of of the wheel. This is the screw closest to the ground when the bag is upright.
    • Remove the bolt by pulling it straight out of the hole.
  3. Replacing a Wheel on your Patagonia Wheeled Luggage: passo 3, imagem 1 %32 Replacing a Wheel on your Patagonia Wheeled Luggage: passo 3, imagem 2 %32
    • Using one hand to lift and support the bag, take the wheel in your other hand. Pull the wheel out of its casing.
    • Removing the wheel may take a little force, do not be afraid to give it a tug.
    • To install your replacement wheel, follow these steps in reverse order with your new wheel.
Linha de Chegada
5 outras pessoas executaram este guia.
Brittany McCrigler
Membro desde: 03/05/12
88.250 Reputação
132 Guias de autoria
Equipe
iFixit Membro de iFixit
Community
140 Membros
17.590 Guias de autoria
2 comentários
What do you do when the nut inside the wheel housing comes loose? I can hear it rolling around in the housing. The bolt has nothing to screw back into. Is there any way to take the housing off? It looks to be held on by rivets. I'm guessing that's not a good sign.
Derek Emanuel - Responder
Helpful but where do you get the replacement wheel from. My brand new Black Hole 100L bag showed up in Lisbon Portugal with one wheel missing. Need to get another wheel and screw. Can I order that from Patagonia and have them ship to a friend that is coming here? Is that best route to take? Thanks
Craig Klinger - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 18
Últimos 30 dias: 123
Duração total: 9,729
