Ir para o conteúdo principal
Replacing a Torn Bike Seat
O que você precisa
  1. Replacing a Torn Bike Seat, Bike Seat Cover: passo 1, imagem 1 %32 Replacing a Torn Bike Seat, Bike Seat Cover: passo 1, imagem 2 %32 Replacing a Torn Bike Seat, Bike Seat Cover: passo 1, imagem 3 %32
    • Use a wrench or electrical wrench to loosen the bolt located on the bike frame near the seat post.
    • Once the bolt is loose, pull the seat post out of the bike frame.
  2. Replacing a Torn Bike Seat: passo 2, imagem 1 %32 Replacing a Torn Bike Seat: passo 2, imagem 2 %32 Replacing a Torn Bike Seat: passo 2, imagem 3 %32
    • Orient the bottom of the bike seat so it's facing you, and place the short end of the Allen key into the bolt.
    • Rotate the Allen key counterclockwise to unscrew the bolt until the clamp is loose.
    • Slide the seat and seat clamp off the railings of the bike.
    • Keep track of the orientation of the seat clamp as you will have to reinstall the bike seat with the same orientation of the seat clamp.
  3. Replacing a Torn Bike Seat: passo 3, imagem 1 %32 Replacing a Torn Bike Seat: passo 3, imagem 2 %32 Replacing a Torn Bike Seat: passo 3, imagem 3 %32
    • Use a metal spudger to remove the staples on the perimeter of the bike seat.
    • Carefully peel the old leather material off the bike seat.
  4. Replacing a Torn Bike Seat: passo 4, imagem 1 %32 Replacing a Torn Bike Seat: passo 4, imagem 2 %32
    • Place your bike seat on top of the new leather material and measure out enough leather to generously cover the entire top and sides of the bike seat.
    • Mark a line around the perimeter of the material and cut along this line.
    • Make sure the foam of your bike seat is dry and free of moisture before proceeding to the next step.
  5. Replacing a Torn Bike Seat: passo 5, imagem 1 %32 Replacing a Torn Bike Seat: passo 5, imagem 2 %32 Replacing a Torn Bike Seat: passo 5, imagem 3 %32
    • Place the bike seat upright on a surface you don’t mind getting dirty and spray the foam seat thoroughly with adhesive spray.
    • Carefully press the cutout leather sheet onto the top of the bike seat.
    • Try to minimize wrinkles or air pockets to allow for a tight fit.
    • Smooth the leather out, and carefully apply the rest of the leather sheet to the remainder of the foam seat.
  6. Replacing a Torn Bike Seat: passo 6, imagem 1 %32 Replacing a Torn Bike Seat: passo 6, imagem 2 %32 Replacing a Torn Bike Seat: passo 6, imagem 3 %32
    • Keep all body parts clear of the heavy-duty staple gun and hold it firmly against the leather material.
    • Press the leather sheet down as close to the bike seat as you can in a desired starting location. Allow it to fold, if necessary.
    • Hold the staple gun directly against the leather and flush with the surface of the bike seat. Press down firmly, and staple the leather in place.
    • If the staple doesn’t go through on your first try, that is fine. Use the screwdriver to remove the staple, and try again.
    • Continue stapling the leather all around the bike seat until the leather is secure, folding or cutting excess as necessary.
  7. Replacing a Torn Bike Seat: passo 7, imagem 1 %32 Replacing a Torn Bike Seat: passo 7, imagem 2 %32
    • Use scissors to cut any excess leather from the inside edge of the seat.
  8. Replacing a Torn Bike Seat: passo 8, imagem 1 %32 Replacing a Torn Bike Seat: passo 8, imagem 2 %32 Replacing a Torn Bike Seat: passo 8, imagem 3 %32
    • Assemble the bike seat in the original clamp orientation that was observed in Step 2.
    • Slide the seat clamp onto the railing located on the underside of the bike seat.
    • Once positioned, insert the short end of the Allen key into the bolt.
    • Rotate the Allen key clockwise to screw the bolt in and tighten the seat clamp to the bike seat.
    • Make sure that the bike seat is positioned and tightened properly before usage to prevent injury.
  9. Replacing a Torn Bike Seat: passo 9, imagem 1 %32 Replacing a Torn Bike Seat: passo 9, imagem 2 %32
    • With the seat on the seat post, lower the post’s metal tube back into the bike’s seat post holder to your desired height.
    • Tighten the bolt on the bike frame following the instructions provided in Step 1.
Conclusão
Pooja Mehta
Membro desde: 04/19/23
169 Reputação
Autoria de 1 guia
Equipe
UCD-MORRIS-S23S1G7 Membro de UCD-MORRIS-S23S1G7
Community
Membros da 3
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 48
Duração total: 430
