Introdução
With frequent usage and exposure to weather, it can be very easy for a bike saddle to rip or degrade over time. As a bike seat is worn down, it becomes less ergonomic, and bike seats are a critical component to biking comfortably. A worn bike seat can cause minor bodily injuries and affect a biker’s concentration on the road. This guide covers how to replace a torn bike seat with a new leather cover to provide a better biking experience.
O que você precisa
Use a wrench or electrical wrench to loosen the bolt located on the bike frame near the seat post.
Once the bolt is loose, pull the seat post out of the bike frame.
Place the bike seat upright on a surface you don’t mind getting dirty and spray the foam seat thoroughly with adhesive spray.
Carefully press the cutout leather sheet onto the top of the bike seat.
Smooth the leather out, and carefully apply the rest of the leather sheet to the remainder of the foam seat.
Press the leather sheet down as close to the bike seat as you can in a desired starting location. Allow it to fold, if necessary.
Hold the staple gun directly against the leather and flush with the surface of the bike seat. Press down firmly, and staple the leather in place.
If the staple doesn’t go through on your first try, that is fine. Use the screwdriver to remove the staple, and try again.
Continue stapling the leather all around the bike seat until the leather is secure, folding or cutting excess as necessary.
Assemble the bike seat in the original clamp orientation that was observed in Step 2.
Slide the seat clamp onto the railing located on the underside of the bike seat.
Once positioned, insert the short end of the Allen key into the bolt.
Rotate the Allen key clockwise to screw the bolt in and tighten the seat clamp to the bike seat.
