Ir para o conteúdo principal
Replacing a TAE/DSL Socket with a RJ45 Jack
O que você precisa
  1. Replacing a TAE/DSL Socket with a RJ45 Jack, Remove the old socket: passo 1, imagem 1 %32 Replacing a TAE/DSL Socket with a RJ45 Jack, Remove the old socket: passo 1, imagem 2 %32
    • Unscrew and remove the cover.
    • If you want to add an RJ45 jack but only have access to the first (non-replaceable) TAE outlet, you can mount the new RJ45 outlet next to it. Connect La on the new outlet to pin 6 of the old TAE outlet, and Lb to pin 5. You can use any type of shielded twisted pair cable for the connection.
    • Remove the the connections.
    • Keep track of La and Lb. You’ll need to know what wires to connect where in the new socket.
    • Unscrew the socket from the wall.
  2. Replacing a TAE/DSL Socket with a RJ45 Jack, Mount the new socket: passo 2, imagem 1 %32
    • Screw the new socket cover to the wall.
    • Refer to the manual that came with your outlet for this step.
  3. Replacing a TAE/DSL Socket with a RJ45 Jack, Punch down the wires: passo 3, imagem 1 %32
    • If you don’t know how to use a punch down tool, take a look at this guide first.
    • Connect La to pin 4 (Blue).
    • Connect Lb to pin 5 (White-Blue).
  4. Replacing a TAE/DSL Socket with a RJ45 Jack, Mount the socket: passo 4, imagem 1 %32
    • Mount the RJ45 socket inside the case and screw on the faceplate.
Conclusão
Have fun surfing the web!
Uma outra pessoa concluiu este guia.
Sebastian
Membro desde: 08/19/18
31.160 Reputação
Autoria de 71 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 48
Últimos 7 dias: 356
Últimos 30 dias: 1,433
Ao todo: 22,535
