Ir para o conteúdo principal
Replacing a Sprinkler Extension
O que você precisa
  1. Replacing a Sprinkler Extension, Sprinkler Extension: passo 1, imagem 1 %32
    • Dig a one foot wide hole around the broken sprinkler extension down to the pipe fitting.
    • The pipe fitting is usually about one foot underground.
  2. Replacing a Sprinkler Extension: passo 2, imagem 1 %32
    • Dig around the pipe fitting with a trowel to provide clear access.
  3. Replacing a Sprinkler Extension: passo 3, imagem 1 %32
    • Clean the area around the fitting with water until the fitting is mostly free of dirt.
  4. Replacing a Sprinkler Extension: passo 4, imagem 1 %32 Replacing a Sprinkler Extension: passo 4, imagem 2 %32
    • Unscrew the sprinkler extension from the pipe fitting.
    • Once the extension is removed, water may come out of the open pipe fitting.
  5. Replacing a Sprinkler Extension: passo 5, imagem 1 %32
    • Screw the new sprinkler extension in securely.
  6. Replacing a Sprinkler Extension: passo 6, imagem 1 %32 Replacing a Sprinkler Extension: passo 6, imagem 2 %32
    • Test the sprinkler to ensure that there are no leaks.
    • Refill the hole tightly.
Conclusão
If you have completed the steps successfully you should have a fully functioning sprinkler extension.
Abagayle Serreyn
Membro desde: 09/11/15
111 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 16
Ao todo: 937
