Ir para o conteúdo principal
Replacing a Broken/Cracked Window Blind Slat
O que você precisa
  1. Replacing a Broken/Cracked Window Blind Slat, Window Blind Slat: passo 1, imagem 1 %32 Replacing a Broken/Cracked Window Blind Slat, Window Blind Slat: passo 1, imagem 2 %32
    • Adjust the angle of the blinds until every slat is flat or laying horizontally using the blind's wand.
  2. Replacing a Broken/Cracked Window Blind Slat: passo 2, imagem 1 %32 Replacing a Broken/Cracked Window Blind Slat: passo 2, imagem 2 %32 Replacing a Broken/Cracked Window Blind Slat: passo 2, imagem 3 %32
    • Carefully remove the damaged slat by cutting the slant halfway across its width, at the point where it is connected to the rest of the blind, with a pair of 8-inch 'Westcott' scissors.
    • Remove the damaged slat from the blind after it has been cut on both sides.
  3. Replacing a Broken/Cracked Window Blind Slat: passo 3, imagem 1 %32
    • Choose an un-cracked slat from a part of the blind that is unaffected during normal use - preferably from the very bottom of the blind.
  4. Replacing a Broken/Cracked Window Blind Slat: passo 4, imagem 1 %32 Replacing a Broken/Cracked Window Blind Slat: passo 4, imagem 2 %32 Replacing a Broken/Cracked Window Blind Slat: passo 4, imagem 3 %32
    • Carefully cut the selected slat halfway across its width, at its two connected points.
    • Carefully remove the replacement slat from its old position, making sure to not extend the cut you made past halfway of the slats width.
  5. Replacing a Broken/Cracked Window Blind Slat: passo 5, imagem 1 %32 Replacing a Broken/Cracked Window Blind Slat: passo 5, imagem 2 %32 Replacing a Broken/Cracked Window Blind Slat: passo 5, imagem 3 %32
    • Carefully place the replacement slat it into its new position.
    • Connect the replacement slat to the support strings at the points where the cuts were made.
  6. Replacing a Broken/Cracked Window Blind Slat: passo 6, imagem 1 %32 Replacing a Broken/Cracked Window Blind Slat: passo 6, imagem 2 %32 Replacing a Broken/Cracked Window Blind Slat: passo 6, imagem 3 %32
    • Tear off a small piece of invisible tape from the roll of tape and carefully place it over the cuts that were made on the replacement slat.
    • Apply tape over the top and bottom of the cuts, on both sides of the replacement slat.
  7. Replacing a Broken/Cracked Window Blind Slat: passo 7, imagem 1 %32 Replacing a Broken/Cracked Window Blind Slat: passo 7, imagem 2 %32
    • Twist the wand of the window blind to test it after applying the tape to both sides of the replacement slat.
    • If the replacement slat stays in its new position then congratulations, you have completed the fix!
Conclusão
Moses Matovu
Membro desde: 03/22/21
145 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 28
Últimos 30 dias: 142
Duração total: 4,771
