Ir para o conteúdo principal
Replacing VuPoint DC-ST210-VP View Finder
O que você precisa
  1. Replacing VuPoint DC-ST210-VP View Finder, Turn Off/Remove Batteries: passo 1, imagem 1 %32
    • Hold the on/off button for 3 seconds until the screen is black.
    • Remove batteries by placing thumb on battery plate cover sliding it down to expose batteries.
    • Turn camera upside down to allow the batteries to fall out.
  2. Replacing VuPoint DC-ST210-VP View Finder, Remove Screws: passo 2, imagem 1 %32 Replacing VuPoint DC-ST210-VP View Finder, Remove Screws: passo 2, imagem 2 %32 Replacing VuPoint DC-ST210-VP View Finder, Remove Screws: passo 2, imagem 3 %32
    • There are 5 (4.5mm in length) screws on the sides of the camera that need to be removed. Use a Phillips #000 screwdriver to remove all screws.
    • Remove 2 screws on the right side of the camera, and store them on a magnetic mat.
    • Remove 2 screws on the bottom of the camera, and store them on a magnetic mat.
    • Remove 1 screw on the left side of the camera, and store it on a magnetic mat.
  3. Replacing VuPoint DC-ST210-VP View Finder, Pry Backplate Off: passo 3, imagem 1 %32 Replacing VuPoint DC-ST210-VP View Finder, Pry Backplate Off: passo 3, imagem 2 %32
    • Using a prying tool or fingernail, gently separate the back plate from the front plate, exposing the inside of the camera.
  4. Replacing VuPoint DC-ST210-VP View Finder, Remove View Finder: passo 4, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Use fingers or tweezers to gently lift view finder out of socket.
    • Clean with general lens cleaner and microfiber fabric as necessary and replace.
Conclusão
Dorey Chiu
Membro desde: 10/26/14
1 Reputação
Autoria de 1 guia
Equipe
Baylor, Team 8-15, Williams Fall 2014 Membro de Baylor, Team 8-15, Williams Fall 2014
BU-WILLIAMS-F14S8G15
3 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 36
Ao todo: 526
