Introdução
The PODZ port is located on the back face of the Ion Air Pro. This port allows the WI-Fi PODZ Pack accessory to be installed.
O que você precisa
Remove the 6 screws securing the lens cover bezel using a #00 Phillips screwdriver. This will allow you to remove the bezel and lens cover.
Quase terminado!
Conclusão
Um comentário
How do you reconnect the ribbon cable to the back of the PODZ port when you reassemble?
