Ir para o conteúdo principal
Replacing Strings on a Mandolin
O que você precisa
  1. Replacing Strings on a Mandolin, Mandolin Strings: passo 1, imagem 1 %32
    • Place the mandolin on a firm, level surface with adequate lighting.
  2. Replacing Strings on a Mandolin: passo 2, imagem 1 %32
    • Loosen the tuning nob.
    • Carefully remove the top end of string from the tuner in the mandolin head.
  3. Replacing Strings on a Mandolin: passo 3, imagem 1 %32
    • Unhook the old string from the tail of the mandolin.
    • Remove the string from the bottom.
  4. Replacing Strings on a Mandolin: passo 4, imagem 1 %32
    • Select a new string, and then insert the bottom end of it through the bridge at the tail.
  5. Replacing Strings on a Mandolin: passo 5, imagem 1 %32
    • Secure the string to the tail by looping it over the hook.
  6. Replacing Strings on a Mandolin: passo 6, imagem 1 %32
    • Pulling the string taut, bring its top end across the nut and into the tuning peg.
  7. Replacing Strings on a Mandolin: passo 7, imagem 1 %32
    • Run the line through the tuning element at the head of the mandolin, as pictured. Be sure to pull the string away from the headstock.
  8. Replacing Strings on a Mandolin: passo 8, imagem 1 %32 Replacing Strings on a Mandolin: passo 8, imagem 2 %32
    • Pull the string down, towards the fretboard, and run the string underneath itself.
    • Pull the string tight so that it wraps around the tuning peg.
  9. Replacing Strings on a Mandolin: passo 9, imagem 1 %32
    • Pinch the string over itself to create a knot.
  10. Replacing Strings on a Mandolin: passo 10, imagem 1 %32
    • Tighten the tuning nob until the desired tension is reached.
  11. Replacing Strings on a Mandolin: passo 11, imagem 1 %32
    • Clip off any excess string.
  12. Replacing Strings on a Mandolin: passo 12, imagem 1 %32
    • Optional: Clip the electronic tuning device to the head of the mandolin; use the device to assist in fine-tuning your mandolin.
  13. Replacing Strings on a Mandolin: passo 13, imagem 1 %32
    • Commence rocking on with your Gretsch New Yorker!
Linha de Chegada
3 outras pessoas executaram este guia.
Drew
Membro desde: 03/18/15
125 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 24
Ao todo: 7,739
