Introdução
Your guitar will eventually need its strings replaced, but online guides may not suit your particular guitar. This guide is for those with a floating tremolo bridge. It will walk you through safely and effectively replacing the strings, ensuring they remain in good condition longer.
For Step 8, when cutting off excess string, be cautious with steel strings as the ends are sharp.
Ensure the guitar is not plugged into any power source before you start.
O que você precisa
Use a string winder to loosen each string by turning the peg counter-clockwise.
Once loosened, pull the string out of the tuning peg.
All that's left to do is tune your guitar and then it will be ready for playing!
