Ir para o conteúdo principal
Snapfon ez One Motherboard Replacement
O que você precisa
  1. Snapfon ez One Motherboard Replacement, Remove the battery cover: passo 1, imagem 1 %32
    • Turn off the phone to prevent data loss.
    • Press and slide the battery out to remove it.
    • Picture rights belong to Snapfon®. Picture is used for educational purposes only. No copyright infringement intended.
  2. Snapfon ez One Motherboard Replacement, Remove the battery: passo 2, imagem 1 %32
    • Pry the battery out with your thumb or the iFixit opening tool.
    • Make sure to properly dispose of the old battery at a recycling center.
  3. Snapfon ez One Motherboard Replacement, Removing the plastic inserts: passo 3, imagem 1 %32 Snapfon ez One Motherboard Replacement, Removing the plastic inserts: passo 3, imagem 2 %32
    • Remove the four rubber inserts from the screw holes using a pair of tweezers.
  4. Snapfon ez One Motherboard Replacement, Remove the shield screws: passo 4, imagem 1 %32 Snapfon ez One Motherboard Replacement, Remove the shield screws: passo 4, imagem 2 %32 Snapfon ez One Motherboard Replacement, Remove the shield screws: passo 4, imagem 3 %32
    • Remove the four 3.1mm screws in the corners with a Phillips #00 screwdriver.
  5. Snapfon ez One Motherboard Replacement, Separate the case: passo 5, imagem 1 %32 Snapfon ez One Motherboard Replacement, Separate the case: passo 5, imagem 2 %32 Snapfon ez One Motherboard Replacement, Separate the case: passo 5, imagem 3 %32
    • Separate the front case from the back case.
    • Remove the metal bumper from the front case’s perimeter.
  6. Snapfon ez One Motherboard Replacement, Remove the volume slider: passo 6, imagem 1 %32
    • Pry the volume slider button out with tweezers.
    • The volume slider button may fall out during the separation of the front and back cases. This is OK.
  7. Snapfon ez One Motherboard Replacement, Remove the motherboard: passo 7, imagem 1 %32 Snapfon ez One Motherboard Replacement, Remove the motherboard: passo 7, imagem 2 %32 Snapfon ez One Motherboard Replacement, Remove the motherboard: passo 7, imagem 3 %32
    • Separate the circuit board from the inside of the back case by prying between them with the opening tool.
    • The last picture is a view of the back of the circuit board.
Conclusão
John Bender
Membro desde: 03/26/14
818 Reputação
Autoria de 8 guias
Equipe
Clemson, Team 6-5, Benson Spring 2014 Membro de Clemson, Team 6-5, Benson Spring 2014
CLEM-BENSON-S14S6G5
Membros da 3
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 205
