Ir para o conteúdo principal
Replacing Samsung Galaxy S4 SIM Card
O que você precisa
  1. Replacing Samsung Galaxy S4 SIM Card, Rear Case: passo 1, imagem 1 %32 Replacing Samsung Galaxy S4 SIM Card, Rear Case: passo 1, imagem 2 %32
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  2. Replacing Samsung Galaxy S4 SIM Card: passo 2, imagem 1 %32 Replacing Samsung Galaxy S4 SIM Card: passo 2, imagem 2 %32 Replacing Samsung Galaxy S4 SIM Card: passo 2, imagem 3 %32
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  3. Replacing Samsung Galaxy S4 SIM Card, MicroSD Card: passo 3, imagem 1 %32 Replacing Samsung Galaxy S4 SIM Card, MicroSD Card: passo 3, imagem 2 %32 Replacing Samsung Galaxy S4 SIM Card, MicroSD Card: passo 3, imagem 3 %32
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  4. Replacing Samsung Galaxy S4 SIM Card, Battery: passo 4, imagem 1 %32 Replacing Samsung Galaxy S4 SIM Card, Battery: passo 4, imagem 2 %32 Replacing Samsung Galaxy S4 SIM Card, Battery: passo 4, imagem 3 %32
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
    • Remove the battery from your phone.
  5. Replacing Samsung Galaxy S4 SIM Card, SIM Card: passo 5, imagem 1 %32 Replacing Samsung Galaxy S4 SIM Card, SIM Card: passo 5, imagem 2 %32 Replacing Samsung Galaxy S4 SIM Card, SIM Card: passo 5, imagem 3 %32
    • Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
    • Remove the SIM card.
    • During reassembly, push the SIM card into the slot until it clicks in place.
Conclusão
78 outras pessoas executaram este guia.
Sam Goldheart
Membro desde: 10/18/12
463.071 Reputação
Autoria de 538 guias
Equipe
iFixit Membro de iFixit
Community
Membros da 142
Autoria de 16.177 guias
3 comentários
Can you take one sim card slot out one galaxy s4 and put it in another or do u have to buy a new one
marius williams - Responder
Somethings wrong with sim card start shut out since July 5 evening and today July 6 three times
humeston23 - Responder
Removing sim card tray?
G M Chadwick - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 51
Últimos 30 dias: 250
Duração total: 244,456
