Ir para o conteúdo principal
Replacing Olympus Stylus Tough-6000 Battery/Memory Card Cover Lock
O que você precisa
  1. Replacing Olympus Stylus Tough-6000 Battery/Memory Card Cover Lock, Locate the Battery/Memory Card Cover Lock.: passo 1, imagem 1 %32
    • Turn the camera over so the bottom is facing upwards.
  2. Replacing Olympus Stylus Tough-6000 Battery/Memory Card Cover Lock: passo 2, imagem 1 %32
    • Pull open the latch on the right hand side to expose the two screws holding the lock in place.
    • Use your Phillips #00 screwdriver to remove both of the screws.
  3. Replacing Olympus Stylus Tough-6000 Battery/Memory Card Cover Lock: passo 3, imagem 1 %32
    • Remove the small black lock from the latch.
  4. Replacing Olympus Stylus Tough-6000 Battery/Memory Card Cover Lock: passo 4, imagem 1 %32
    • Open the latch on the left hand side
    • Remove the single screw with your Phillips #00 screwdriver.
  5. Replacing Olympus Stylus Tough-6000 Battery/Memory Card Cover Lock: passo 5, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Use your tweezers for this step.
    • After you have removed the screw holding down the cover you will see a single spring.
    • Make sure spring is in place to be able to close lock properly.
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 27
Ao todo: 1,117
