Introdução
Occasionally, even when you take care of your sunglasses very carefully, you may need to replace parts to extend the life of your sunglasses.
This guide will show you how to replace the the rubber ear socks, nose pads and the lens on the Oakley Flak 2 sunglasses. Before using this guide please ensure that the rubber kits and lens are made for the Oakley Flak 2.0, as any other lens or kits will not fit onto the frames.
This guide can be done completely toolless. Certain tools were used for this guide to make the task easier than if done by hand alone.
O que você precisa
Pinch the tweezers and place them against the rubber ear socket.
Push the tweezers through the hole.
Slowly pull out the rubber ear sock.
Use a micro-fiber cloth to clean the lens.
This guide can allow you to mix and match various rubber kits, and lens to create your own Oakley Flak 2 sunglasses.
