Ir para o conteúdo principal
Replacing Oakley Flak 2 Lens and Rubber Kits
O que você precisa
  1. Replacing Oakley Flak 2 Lens and Rubber Kits, Lens & Rubber Kits: passo 1, imagem 1 %32 Replacing Oakley Flak 2 Lens and Rubber Kits, Lens & Rubber Kits: passo 1, imagem 2 %32 Replacing Oakley Flak 2 Lens and Rubber Kits, Lens & Rubber Kits: passo 1, imagem 3 %32
    • Pinch the tweezers and place them against the rubber ear socket.
    • Push the tweezers through the hole.
    • Slowly pull out the rubber ear sock.
    • Repeat the previous steps for the other side.
  2. Replacing Oakley Flak 2 Lens and Rubber Kits: passo 2, imagem 1 %32 Replacing Oakley Flak 2 Lens and Rubber Kits: passo 2, imagem 2 %32
    • Pull up on the bottom of the rubber nose pad.
    • Push the rubber nose pad up to remove it.
    • Repeat the steps for the other side.
  3. Replacing Oakley Flak 2 Lens and Rubber Kits: passo 3, imagem 1 %32 Replacing Oakley Flak 2 Lens and Rubber Kits: passo 3, imagem 2 %32
    • From the bridge of the glasses, push the bottom outer corner of the lens up.
    • Use the groove to slide the dislodged side of the lens down and out.
  4. Replacing Oakley Flak 2 Lens and Rubber Kits: passo 4, imagem 1 %32 Replacing Oakley Flak 2 Lens and Rubber Kits: passo 4, imagem 2 %32 Replacing Oakley Flak 2 Lens and Rubber Kits: passo 4, imagem 3 %32
    • Make sure to match the correct ear sock to the correct temple side.
    • Insert the glasses temple in the rubber sock
    • Push/ Pull the rubber sock forward.
    • Push in the rubber tab into the hole near the hinge.
  5. Replacing Oakley Flak 2 Lens and Rubber Kits: passo 5, imagem 1 %32 Replacing Oakley Flak 2 Lens and Rubber Kits: passo 5, imagem 2 %32 Replacing Oakley Flak 2 Lens and Rubber Kits: passo 5, imagem 3 %32
    • Insert the rubber nose pad from the top.
    • Stretch the nose pad at the bottom and insert the bottom tab into nose pad.
  6. Replacing Oakley Flak 2 Lens and Rubber Kits: passo 6, imagem 1 %32 Replacing Oakley Flak 2 Lens and Rubber Kits: passo 6, imagem 2 %32 Replacing Oakley Flak 2 Lens and Rubber Kits: passo 6, imagem 3 %32
    • Insert the lens from the outer top corner.
    • Push the bottom corner of the lens closest to the frame's bridge up. An auditable pop will indicate the lens is inserted.
    • Repeat these steps for the other side.
  7. Replacing Oakley Flak 2 Lens and Rubber Kits: passo 7, imagem 1 %32 Replacing Oakley Flak 2 Lens and Rubber Kits: passo 7, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Microfiber Cleaning Cloths
    $3.99
    Comprar
Conclusão
This guide can allow you to mix and match various rubber kits, and lens to create your own Oakley Flak 2 sunglasses.
Peter Tran
Membro desde: 07/02/21
193 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 18
Últimos 30 dias: 70
Duração total: 1,891
