Ir para o conteúdo principal
Replacing Motorola V60i Logic Board
O que você precisa
  1. Replacing Motorola V60i Logic Board, Battery: passo 1, imagem 1 %32 Replacing Motorola V60i Logic Board, Battery: passo 1, imagem 2 %32
    • Flip the phone over so the back cover is facing up.
    • Using either a finger or a spudger, press the button located near the top of the phone by the antenna.
  2. Replacing Motorola V60i Logic Board: passo 2, imagem 1 %32 Replacing Motorola V60i Logic Board: passo 2, imagem 2 %32
    • Pry up the back plate from the phone.
    • Push the button near the bottom of the battery using either your finger or the spudger to release the battery.
  3. Replacing Motorola V60i Logic Board, Back Plate: passo 3, imagem 1 %32
    • Using a T6 Torx screwdriver, remove the four screws from the back of the phone.
  4. Replacing Motorola V60i Logic Board: passo 4, imagem 1 %32 Replacing Motorola V60i Logic Board: passo 4, imagem 2 %32
    • Simultaneously press the highlighted buttons on both sides of phone.
  5. Replacing Motorola V60i Logic Board: passo 5, imagem 1 %32
    • Separate the back plate from the rest of phone.
    • Do not pull the wire connecting the front and back plates.
  6. Replacing Motorola V60i Logic Board, Motherboard: passo 6, imagem 1 %32
    • Gently lift logic board from back plate.
  7. Replacing Motorola V60i Logic Board: passo 7, imagem 1 %32 Replacing Motorola V60i Logic Board: passo 7, imagem 2 %32
    • Place logic board on front cover.
    • Unsnap orange wire that connects the logic board to keypad sensor to allow the logic board to move freely.
Conclusão
Equipe
Cal Poly, Team 30-40, Garner Spring 2010 Membro de Cal Poly, Team 30-40, Garner Spring 2010
CPSU-GARNER-S10S30G40
Membros da 4
Autoria de 14 guias
Um comentário
Quero comprar esse aparelho, alguém tem para vender?
Karison Mesquita - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 16
Duração total: 2,183
