Introdução
This guide will demonstrate how to remove and replace the screen on an IBM ThinkPad 560z. A Phillips 00 screwdriver and a push pin are needed for this process.
Peças
Não são necessárias peças.
  1. Slide the battery release latch to the right.
    • Slide the battery release latch to the right.
    • Pull out the battery out towards the front of the device.
  2. Remove the plastic screw covers, then remove the 3 Phillips screws under them.
    • Remove the plastic screw covers, then remove the 3 Phillips screws under them.
    • Insert the plastic opening tool between the front cover and back cover to pry open the screen case, then carefully pull the bezel off.
    • Remove the four Phillips head screws.
    • Using your fingers or an Opening Tool, detach the connector on the right side of the screen.
    • Slowly pull back the screen from the top and disconnect the ribbon cable from the back to completely free the screen from the laptop.
      • The connector is very fragile, so be careful.
Conclusão
2 outras pessoas concluíram este guia.
John Allande
64 reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 26-27, Regan Spring 2010 Membro de Cal Poly, Team 26-27, Regan Spring 2010
CPSU-REGAN-S10S26G27
3 Membros
18 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Todo: 4,541
