Ir para o conteúdo principal
Replacing Crosley CR704 Needle
O que você precisa
  1. Replacing Crosley CR704 Needle, Needle: passo 1, imagem 1 %32
    • With steady hands, gently tug the needle from its cartridge pulling downwards.
    • There will be a slight resistance.
  2. Replacing Crosley CR704 Needle: passo 2, imagem 1 %32
    • Secure the new needle by gently snapping it upwards an inwards until it clicks into place.
    • Be careful not to touch the stylus tip when handling the tone arm. This is what plays your records.
Conclusão
Test by playing a record. We suggest "Revolver" by the Beatles.
MarkAnthony
Membro desde: 09/22/13
772 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 1-4, Gulbrandsen Fall 2013 Membro de UMass Dartmouth, Team 1-4, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S1G4
3 Membros
Autoria de 5 guias
Um comentário
2 steps with the same pic for both.
Really?
John Pottle - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 15
Ao todo: 18,332
