O que você precisa
Vídeo de Apresentação
A video about replacing Navigation in BMW E39 http://www.youtube.com/watch?v=rmcAAYLmL....
Replacing a faulty Navigation computer CD or DVD drive or Upgrading an older navigation CD drive to the BMW DVD Navigation Drive is a plug and play upgrade in all model years
BMW MKIV DVD Navigation drives can be purchased from online retailers. Do a google search for "BMW MKIV Navigation Computer" for available options
Different BMW models require a slightly different process to remove the navigation computer however all are generally the same. The following photos show removing the navigation computer in a BMW E38 7 Series
In the back of the car locate the navigation computer drive and insert 4 pieces of a cutup coat hanger or a "Radio Removal Tool" into the holes of the drive
Once the tools are in the holes you can grasp the navigation drive faceplate and slide it out
Photo shows closeup of where the tools release the locking mechanism
If your BMW is a 2000 Model Year or older, you will need to disconnect the separate GPS receiver located to the left of the navigation drive in the E38 or behind the amplifier bracket in the BMW E39
Once disconnected, connect the antennna wire to the back of the new navigation drive and remove the old separate GPS module as it will no longer be required
6 outras pessoas executaram este guia.
3 comentários
Thanks buddy for your instructions
Whether you're searching for a ride to the air terminal, or a limo to get you and take you to a gathering in the city, Birds Wing is your finished ground transportation answer for and from the air terminal. Our drivers are expertly prepared and will take extraordinary consideration of you and your family or business partners. Boston Car Service to Airport
Boston Logan Airport Car Service
