Introdução
This is a walk through of how to replace the spark plugs in a Dodge Neon. This demonstration is on a 1998 model.
The air vent is covering 4 spark plugs.
Twist off the wing nut on the left (see hand in photo).
The big plastic art with the "SO??" marked on it just lifts up and out
It sounds like you are breaking something but you are just disconnecting it from the air filter housing.
5 outras pessoas executaram este guia.
2 comentários
How long of an extention rachet do you need to get to the plugs..? Thanks though seems simple enough. Also has anyone changed their plugs in a 98 neon using Bosch Platinum IR infusion plugs... with 4 ground electrodes... I just bought them.. figured they'd work the best... hope not to hot.
