Introdução
Your motherboard is no longer working? This is a real shame, but you have the chance to be on this tutorial that will guide you through the process of replacing it.
O que você precisa
Pop the center cover open on the bottom cover.
Remove the center screw with a #00 Phillips screwdriver.
Use a T5 Torx screwdriver for the remaining screws around the edge of the bottom cover.
Once all the screws have been removed the battery is now safe to extract
Close the laptop, flip the laptop over, and pop off the back small panel with a flathead screwdriver. The panel will be hanging by the hinges once open.
Disconnect the two wires from the WiFi card. You can do this with a pair of pliers or your fingernail.
Remove the screw with a #00 Phillips screwdriver.
Now remove your WiFi card to replace it.
Remove the hard disk from its location.
Remove the connector with a pair of pliers or your fingernail.
Remove the screws with a #00 Phillips screwdriver.
Remove the card afterwards.
Disconnect the various connections from the motherboard.
Carefully turn the motherboard over to disconnect the tablecloth from the keyboard.
You can now replace the motherboard.
To reassemble your device, follow the instructions in reverse order.
Uma outra pessoa concluiu este guia.
Um agradecimento especial a esses tradutores:
100%
Schwarzer está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
