Introdução
There you go! There you go! You have just spilled your glass of Johnnie Walker Black Label on the keyboard of your Dell XPS 12 9Q23 and it no longer works...
What a pity (especially for whisky), but luck is with you, this tutorial will guide you step by step to make the replacement.
PS: This tutorial also works for other drinks spilling on the keyboard or simply to clean them up.)
O que você precisa
Pop the center cover open on the bottom cover.
Remove the center screw with a #00 Phillips screwdriver.
Use a T5 Torx screwdriver for the remaining screws around the edge of the bottom cover.
Once all the screws have been removed the battery is now safe to extract
Close the laptop, flip the laptop over, and pop off the back small panel with a flathead screwdriver. The panel will be hanging by the hinges once open.
Disconnect the two wires from the WiFi card. You can do this with a pair of pliers or your fingernail.
Remove the screw with a #00 Phillips screwdriver.
Now remove your WiFi card to replace it.
Remove the hard disk from its location.
Remove the connector with a pair of pliers or your fingernail.
Remove the screws with a #00 Phillips screwdriver.
Remove the card afterwards.
Disconnect the various connections from the motherboard.
Carefully turn the motherboard over to disconnect the tablecloth from the keyboard.
You can now replace the motherboard.
Remove the screw with a #00 Phillips screwdriver and remove the bracket.
Remove the screw with a #00 Phillips screwdriver and remove the support.
Be patient and unscrew the 24 keyboard screws.
You can now remove the keyboard. And also do a cleaning if necessary, as in the second photo.
To reassemble your device, follow the instructions in reverse order.
Uma outra pessoa concluiu este guia.
Um agradecimento especial a esses tradutores:
100%
Schwarzer está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
