Ir para o conteúdo principal
Replacement of Hardware on a Crossbody bag
O que você precisa
  1. Replacement of Hardware on a Crossbody bag, Hardware on a Crossbody bag: passo 1, imagem 1 %32 Replacement of Hardware on a Crossbody bag, Hardware on a Crossbody bag: passo 1, imagem 2 %32
    • Remove the old stitching with the seam ripper blade.
    • Use the seam ripper blade carefully as it is very sharp.
  2. Replacement of Hardware on a Crossbody bag: passo 2, imagem 1 %32 Replacement of Hardware on a Crossbody bag: passo 2, imagem 2 %32
    • Remove the previous hardware from the strap.
  3. Replacement of Hardware on a Crossbody bag: passo 3, imagem 1 %32
    • Measure, and ensure the new hardware fits.
    • Place the new hardware through the strap.
  4. Replacement of Hardware on a Crossbody bag: passo 4, imagem 1 %32 Replacement of Hardware on a Crossbody bag: passo 4, imagem 2 %32
    • Use the needle and thread to stitch the new hardware into place.
    • Using the adequate needle for the material you need is essential, as some materials may be thicker and need a larger needle.
    • Use needle and thread carefully, as the needle can be sharp.
  5. Replacement of Hardware on a Crossbody bag: passo 5, imagem 1 %32
    • Verify the stitching is secure by hanging the crossbody bag.
Linha de Chegada
Uma outra pessoa concluiu este guia.
joanna
Membro desde: 02/20/24
122 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 62
