Ir para o conteúdo principal
Replacement de la vitre tactile et de l'écran LCD du Samsung Galaxy Note8
O que você precisa
    • Insérer un commentaire.
Linha de Chegada
21 outras pessoas executaram este guia.
ian mdx
Membro desde: 06/30/16
8.968 Reputação
Autoria de 17 guias
9 comentários
Am I to assume that I dont need to reapply or replace glue or adhesive strips? Is simply reheating the previous glue good enough to hold it?
Andrew Gross - Responder
You might get away with re-heating the previously used glue the first time, however you may also notice the screen lifting from the frame. I would suggest using 99% Isopropyl alcohol to remove any excess or poorly positioned glue remaining after removing the LCD and re-applying a small amount of E8000 around the edges where there is glue missing. Posting this answer very late, but only because I know people are still repairing the Note8 using similar guides because it’s how I got here.
Jack Donovan -
note8 siyah ekran bozuldu. fiyat nedir
yasin tufekci - Responder
Mine is coming up saying Note Network found after completion of the repair any ideas?
James Turner - Responder
Will the phone remain waterproof after this repair?
cj-dm - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 9
Duração total: 24,041
