Ir para o conteúdo principal
Replace the cells in bObsweep battery
O que você precisa
  1. Replace the cells in bObsweep battery, Remove the old battery: passo 1, imagem 1 %32
  2. Replace the cells in bObsweep battery, Dissassemble the old battery pack: passo 2, imagem 1 %32
    • Remove the plastic case
    • Carefully peel the plastic cover to expose the cells
    • Draw a diagram of the wiring and then cut the individual cells appart
  3. Replace the cells in bObsweep battery, Rebuild the battery pack: passo 3, imagem 1 %32 Replace the cells in bObsweep battery, Rebuild the battery pack: passo 3, imagem 2 %32
    • Use similar 18650 for rebuilding the pack. Be sure that they are charged at the same level too
    • You can use a normal soldering iron for attaching the nickel strips but it is recommended to use a spot welder. There is a cheap korean option https://m.blog.naver.com/aulakiria/22099...
  4. Replace the cells in bObsweep battery, Shrink wrap it: passo 4, imagem 1 %32 Replace the cells in bObsweep battery, Shrink wrap it: passo 4, imagem 2 %32 Replace the cells in bObsweep battery, Shrink wrap it: passo 4, imagem 3 %32
    • Use the heat shrink wrapping to seal your new battery
  5. Replace the cells in bObsweep battery, Done: passo 5, imagem 1 %32
    • Enjoy few more years with the refreshed battery
Conclusão
Uma outra pessoa concluiu este guia.
Erwin
Membro desde: 07/01/14
217 Reputação
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 228
