Ir para o conteúdo principal
Replace the Slider on a Plastic Tooth Zipper
O que você precisa
Vídeo de Apresentação
  1. Replace the Slider on a Plastic Tooth Zipper, Plastic Zipper Slider: passo 1, imagem 1 %32 Replace the Slider on a Plastic Tooth Zipper, Plastic Zipper Slider: passo 1, imagem 2 %32 Replace the Slider on a Plastic Tooth Zipper, Plastic Zipper Slider: passo 1, imagem 3 %32
    • Locate the top of the zipper on the side with the slider.
    • Use end nippers to cut the stop off of the zipper.
    • Be careful to only cut the plastic, not the fabric.
  2. Replace the Slider on a Plastic Tooth Zipper: passo 2, imagem 1 %32
    • Use tweezers to remove any remaining pieces of the stop from the garment.
  3. Replace the Slider on a Plastic Tooth Zipper: passo 3, imagem 1 %32 Replace the Slider on a Plastic Tooth Zipper: passo 3, imagem 2 %32 Replace the Slider on a Plastic Tooth Zipper: passo 3, imagem 3 %32
    • Slide the slider off of the garment.
  4. Replace the Slider on a Plastic Tooth Zipper: passo 4, imagem 1 %32 Replace the Slider on a Plastic Tooth Zipper: passo 4, imagem 2 %32 Replace the Slider on a Plastic Tooth Zipper: passo 4, imagem 3 %32
    • Insert the new slider onto the zipper.
    • You may need to tug a little to get the slider over the webbing from the old stop.
    • Make sure the zipper slider is oriented right-side up when you slide it back onto the zipper.
    Bonjour, je n’arrive pas à faire descendre le nouveau curseur, seriez vous pourquoi ?
    vcarpentier78 - Responder
    Regardez s’il y a quelque obstruction le long de la fermeture, un bout de fil peut dérailler ou bloquer le curseur ou une dent qui est déformée. Un peu de lubricant pourrait aussi aider. Bonne chance.
    haingu nguyen -
  5. Replace the Slider on a Plastic Tooth Zipper: passo 5, imagem 1 %32 Replace the Slider on a Plastic Tooth Zipper: passo 5, imagem 2 %32 Replace the Slider on a Plastic Tooth Zipper: passo 5, imagem 3 %32
    • Grab a replacement stop.
    • Position the new stop over the webbing in the same place where the old stop was located.
  6. Replace the Slider on a Plastic Tooth Zipper: passo 6, imagem 1 %32 Replace the Slider on a Plastic Tooth Zipper: passo 6, imagem 2 %32
    • Use pliers to crimp the stop into place.
    Incollato. Solo pressione o a caldo?
    Piergiorgio Fol - Responder
    Ciao @piergiorgiofol, da quanto ha capito le istruzioni della guida e il video sopra, bisogna solo premere il fermo sulla fettuccia con l'aiuto delle pinze. Non viene menzionato di scaldare. Forse dipende dal materiale della parte di ricambio che usi, ma l'etichetta o il packaging di questa dovrebbe indicare se c'è qualcosa di speciale a fare per montarla. Buona riparazione!
    Claire Miesch -
Conclusão
For replacement parts or further assistance, contact Patagonia Customer Service.
59 outras pessoas executaram este guia.
Brittany McCrigler
Membro desde: 03/05/12
89.014 Reputação
Autoria de 131 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.817 guias
23 comentários
Where do I get the parts needed?
jonaskrat - Responder
Off of another zipper
nerdyrepair -
Amazon has replacement parts, but I found you can get almost any zipper parts from a sailing supply company called sailrite.com.
Scott Lamorte -
Perfect...thank you! I had seen about 10 other videos on how to do this repair but yours was the one that showed me exactly how to do it and it worked perfectly the first time. Much appreciated!
starrdustt57 - Responder
Thank you! This was great - I ordered the knippers and replacement parts for a jacket of mine that I broke, as I know my children will be breaking there's sooner or later. It cost me $10 instead of $40+ to replace a jacket.
Megan Elmore - Responder
Where did you get the replacement end plastic endstop?
Deborah Spaulding -
I can not thank you enough for this tutorial. I had contacted a seamstress and she said it would have to be replaced. Thank heavens I found your site. The zipper pull has been replaced on the zipper and I'm awaiting my order of stops to replace the top stop. Thank you, Thank you!
Mary Axtell - Responder
Where can I buy the things needed to do this please?
Val Neale - Responder
Amazon or sailrite.com
Scott Lamorte -
Hi
The tutorial is fab and I checked out sailrite for zippers which brings me a step further, but how do I determine the right size zipper. There is no numbers or anything on my current broken zipper. I thought about measuring the bottom or the top and going from that measurement? Any feedback appreciated.
thanks Jenny
Jenny - Responder
Where did you get the replacement stop?
edward schmitt - Responder
I lost the original slider …. how will we know what to buy ?
Rishi Rampaul - Responder
I lost the original slider … how will I know what to buy ?
Sometimes, if the slider is not broken, but it doen’t connect the two sides any more, you can very, very gently squize the upper and lower side of the slider. Most of the times it will be o.k. again.
Paul A. - Responder
You can check other zippers (if any) on pockets as they’re often the same size. A good quality zipper will have the size stamped on the back. Standard exterior coat zippers are size 5.
Sarah Gerber - Responder
Thanks for keeping this tutorial up! I broke a tooth near the bottom stopper on a zipper and this helped me to fashion a fix!
Jamie Saulsbury - Responder
'''Plastic zipper on a comforter coverlet will not stay zipped… it splits on both sides of the zipper. There’s no # on bottom of slider(made in China I think!) so how do I fix it? It’s a small slider.. nothing actually seems to be wrong with the slider! The plastic zipper just won’t start… it gaps open every time you zip it! In front & in back of the slider!!
Marcia - Responder
How can I fix one with the slider (plastic teeth) when the stop is hidden (Sewn in) And I managed to get both sides feeding into the slider just fine but when I zip it, the zipper behind just pulls apart again. (This is on a Large sectional-sized throw pillow) so… it’s on track on both sides, the slider moves, but the zipper won’t stay zipped. It just pulls agape again. Help please
garnetthudnall - Responder
Thanks so much! Zipper fixed in a few minutes :) I just reused the stopper piece too :) Great presentation with excellent video quality =D Thank you ☺️
Lesley Pain - Responder
To determine what type and size of slider you might need, please check out this guide below. Video: Introduction to Zipper Types and Slider Identification
Once you know which type and size you need contact Patagonia Customer Service ( 1-800-638-6464) for a new Slider and Zipper Stop. Please have your type and size available to provide to the CS Agent.
Tools for the job were listed above in the "Tools" section, if you place your cursor over the link a little window will pop up. If you click on it it will take you to a vendor to purchase any tool that needed.
Good Luck.
Marty Chapman - Responder
If your garments were made better the zippers wouldn't break so often. I've had three SST jackets and various zippers have failed on all three. Now I but Rapala Pro jackets - twice the jacket at half the price.
Garnet Brake - Responder
How do I replace jusy 1 tooth toward the middle?
Silky Jones - Responder
Thank You ! Very Helpful ! Yay!
PL Low - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 187
Últimos 7 dias: 1,370
Últimos 30 dias: 5,215
Duração total: 717,175
