Ir para o conteúdo principal
Replace the Slider on a Plastic Tooth Zipper
O que você precisa
Vídeo de Apresentação
  1. Replace the Slider on a Plastic Tooth Zipper, Plastic Zipper Slider: passo 1, imagem 1 %32 Replace the Slider on a Plastic Tooth Zipper, Plastic Zipper Slider: passo 1, imagem 2 %32 Replace the Slider on a Plastic Tooth Zipper, Plastic Zipper Slider: passo 1, imagem 3 %32
    • Locate the top of the zipper on the side with the slider.
    • Use end nippers to cut the stop off of the zipper.
    • Be careful to only cut the plastic, not the fabric.
  2. Replace the Slider on a Plastic Tooth Zipper: passo 2, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use tweezers to remove any remaining pieces of the stop from the garment.
  3. Replace the Slider on a Plastic Tooth Zipper: passo 3, imagem 1 %32 Replace the Slider on a Plastic Tooth Zipper: passo 3, imagem 2 %32 Replace the Slider on a Plastic Tooth Zipper: passo 3, imagem 3 %32
    • Slide the slider off of the garment.
  4. Replace the Slider on a Plastic Tooth Zipper: passo 4, imagem 1 %32 Replace the Slider on a Plastic Tooth Zipper: passo 4, imagem 2 %32 Replace the Slider on a Plastic Tooth Zipper: passo 4, imagem 3 %32
    • Insert the new slider onto the zipper.
    • You may need to tug a little to get the slider over the webbing from the old stop.
    • Make sure the zipper slider is oriented right-side up when you slide it back onto the zipper.
  5. Replace the Slider on a Plastic Tooth Zipper: passo 5, imagem 1 %32 Replace the Slider on a Plastic Tooth Zipper: passo 5, imagem 2 %32 Replace the Slider on a Plastic Tooth Zipper: passo 5, imagem 3 %32
    • Grab a replacement stop.
    • Position the new stop over the webbing in the same place where the old stop was located.
  6. Replace the Slider on a Plastic Tooth Zipper: passo 6, imagem 1 %32 Replace the Slider on a Plastic Tooth Zipper: passo 6, imagem 2 %32
    • Use pliers to crimp the stop into place.
Conclusão
For replacement parts or further assistance, contact Patagonia Customer Service.
59 outras pessoas executaram este guia.
Brittany McCrigler
Membro desde: 03/05/12
89.128 Reputação
Autoria de 131 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 140
Autoria de 18.079 guias
23 comentários
Where do I get the parts needed?
jonaskrat - Responder
Off of another zipper
nerdyrepair -
Amazon has replacement parts, but I found you can get almost any zipper parts from a sailing supply company called sailrite.com.
Scott Lamorte -
Perfect...thank you! I had seen about 10 other videos on how to do this repair but yours was the one that showed me exactly how to do it and it worked perfectly the first time. Much appreciated!
starrdustt57 - Responder
Thank you! This was great - I ordered the knippers and replacement parts for a jacket of mine that I broke, as I know my children will be breaking there's sooner or later. It cost me $10 instead of $40+ to replace a jacket.
Megan Elmore - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 127
Últimos 7 dias: 933
Últimos 30 dias: 4,028
Duração total: 731,526
