Ir para o conteúdo principal
Replace Logitech MX mechanical key
O que você precisa
  1. Replace Logitech MX mechanical key, Remove keycaps: passo 1, imagem 1 %32 Replace Logitech MX mechanical key, Remove keycaps: passo 1, imagem 2 %32
    Ferramenta utilizada neste passo:
    Keycap Puller
    $6.95
    • Use a keycap remover tool / opening tool or your hands to remove all keycaps.
    • Make a few photos of your keybord layout to have a reference for reassembly later on.
    • If your keybord is dirty use a soft brush to clean it.
  2. Replace Logitech MX mechanical key, Unscrew 20x black screws: passo 2, imagem 1 %32 Replace Logitech MX mechanical key, Unscrew 20x black screws: passo 2, imagem 2 %32
    • Remove 20x black screws with a Philips size 0 screwdriver.
    • Don't loose the screws, put them in a bin or similar.
  3. Replace Logitech MX mechanical key, Open back cover: passo 3, imagem 1 %32 Replace Logitech MX mechanical key, Open back cover: passo 3, imagem 2 %32 Replace Logitech MX mechanical key, Open back cover: passo 3, imagem 3 %32
    • The back cover is held in place by small plastic tabs.
    • Flip the keyboard on its front.
    • There is a small slid between the back cover and the body. Insert a thin plastic opening pick at the top of the keyboard.
    • Use something sturdy, like a metal spudger to release the plastic tabs all around.
    • There is a cable comming from the battery and connecting the plastic cover and the keyboard front. The connecter is clipped into the plastic frame above the PCV and can be unclipped using some tweezers or spudger.
  4. Replace Logitech MX mechanical key, Remove plastic frame above PCB: passo 4, imagem 1 %32 Replace Logitech MX mechanical key, Remove plastic frame above PCB: passo 4, imagem 2 %32 Replace Logitech MX mechanical key, Remove plastic frame above PCB: passo 4, imagem 3 %32
    • Disconnect controller from battery.
    • Disconnect ribbon cable from controller.
    • The plastic frame above the PCB is connected via screws. Unscrew 6x silver screws using a size 2 philips screwdriver.
    • Remove the black plastic frame covering the PCB.
  5. Replace Logitech MX mechanical key, (Optional) Remove screws holding PCB: passo 5, imagem 1 %32 Replace Logitech MX mechanical key, (Optional) Remove screws holding PCB: passo 5, imagem 2 %32
    • There are 4 capped screws (silver) fixing the PCB to the metal part of the keyboard. One hides under the ribon cable.
    • Removing the switches isn't covered by this guide.
    • The switches for this model are Kailh Choc V2 Low Profile Switches.
  6. Replace Logitech MX mechanical key, Mark the defective key: passo 6, imagem 1 %32 Replace Logitech MX mechanical key, Mark the defective key: passo 6, imagem 2 %32
    • To avoid confusion later, mark the defective key. In this case, the “D” key is defective and is marked with a felt-tip pen.
    • Locate and mark the back of the defective key. Each key is connected to the circuit board at three solder points. The black pin is only inserted and not connected to the circuit board.
  7. Replace Logitech MX mechanical key, Desoldering key: passo 7, imagem 1 %32 Replace Logitech MX mechanical key, Desoldering key: passo 7, imagem 2 %32 Replace Logitech MX mechanical key, Desoldering key: passo 7, imagem 3 %32
    • Desolder the three solder joints on the button you marked earlier:
    • Heat the pin until all the existing solder is liquid.
    • Add some fresh solder.
    • Remove the liquid solder with a desoldering pump.
    • After desoldering, you can push the button out from the front.
  8. Replace Logitech MX mechanical key, Solder the replacement key: passo 8, imagem 1 %32 Replace Logitech MX mechanical key, Solder the replacement key: passo 8, imagem 2 %32
    • Insert the replacement key into the gap in the circuit board. It only fits into the gap one way.
    • Re-solder the three solder joints.
Conclusão
To reassemble your device, follow the relevant steps in the instructions in reverse order.
Before replacing all the key caps, test the function of the new key.
Um agradecimento especial a esses tradutores:
de en
100%
oldturkey03 está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
AnHeuermann
Membro desde: 08/26/24
368 Reputação
Autoria de 2 guias
3Comentários do guia
Thank you! This was very helpful. rrh
rrh - Responder
The c-key has had an intermittent problem on my Logitech MX Mechanical Wireless (tactile) and outstanding guide will give me the confidence to give repairing it a go, saving waste and money.
Thank you
Jack - Responder
Thank you ! I just swapped a damaged key with less used healthy key by following this guide. Saved me from an ongoing frustration and money.
P V - Responder
Comentar
Visualizações:
Últimas 24 horas: 20
Últimos 7 dias: 108
Últimos 30 dias: 517
Ao todo: 3,046
